ReverseProxy and htaccess login on the GUI failed
Lacky
Hi everyone,
for security reasons and the unavailability of https I would like to connect to my HC2 through an reverse proxy. This generally works well.
Now I want to protect this access also via .htaccess because I don´t know how secure the login of the HC2-surface is.
I now secure access with htaccess, so the login fails at the HC2-surface. I get the message "wrong password". But the login without .htaccess configuration works well with the same password.
I suspect an error in the code of Fibaro. Can anyone confirm this?
How can i solve this problem?
Thanks in advance
Lacky
5 answers to this question
By not using .htaccess. It will not work.
Use VPN or why not (as I do) port knocking.
Can you explain how you did that JanJoh?
Well, I did i tmy own way.
But here is a pretty darn good guide for the same equipment that I use at my home (MIkrotik), and it is definitely more structured
  • By not using .htaccess. It will not work.
    It will not work, because of an issue in fibaro´s software! For example, with an wordpress installation the login works perfectly!
    VPN is not a solution for me, because i can´t connect over VPN @work. It´s not allowed.
    Port knocking is only possible with additional hardware, right? So this is also not the preferred solution.
    So i will open a ticket  :->
    Thanks, I also do have a Mikrotik, so I'm going to try it.
