Fibaro door/windows sensor don't work after battery changing
Guest berga_s
Guest berga_s
Hi, I have problems with door/windows sensor every time I need to change the battery...
I change the battery with the magnet off (door/window open), some times is OK some time I need to try to exclude and include again more times before everything work well.
This time, for one sensor I wait 2 month before to change the battery starting from the Fibaro messages and now I've tried to change but the sensor doesn't work.
The other times as soon I put inside new battery the led was lighting, but this time nothing happen.
I've try to check the new battery status and is 3,68V (I have 5 new batteries) and I also tried to use a battery from another working sensor but still nothing happen.
I've try to follow the sensor reset procedure, but still nothing happen.
This door/windows sensor have also the temperature module DS18B20.
Any suggestion?
You always have to change the batteries with the door open (with the maget far from the sensor). If not, it makes a reset !
