Dimmer2 S2 controlling FGRGBW
tvs
I have a Dimmer 2 with two switches. I want the S2 to control the on/off & Brightness of a Fibaro RGB Module. I've had the exact same set-up working fine with a Dimmer 1.
The problem I have is the RGB Module doesn't come on with a single click, only with a press and hold. And when it does come on its not at its last state, rather it comes on at the min level.
I don't really understand all the new associations, I currently have it set at EndPoint 0, Group 5, although I've tried Group 4 too. Whats strange is the RGB Module will switch off with a single click, it just won't switch on.
The two Modules are about 3Meters away from each other.
Any help would be greatly appreciated.
cheers
tom
  • I've just tried Associating the Dimmer2 to a Dimmer1 and it works perfectly. It just struggles switching on the RGB strip. I remember I had a similar issue with a Dimmer1 Once and technical support told me the following:
    Krzysztof Gumny 10 Mar 15
    Please set for these two dimmers, parameter number 10 on value 0.
    It should solve your issue.
    Best regards
    But I can't find a Parameter 10 on the dimmer2.
