Guest Kuuno
I ran into a situation where whole zwane network hung. there are about 100 devices.
the problem does not come from HC2 (i turn it off and problem persists)
i can tell it with special 868mhz analyser. it shows how much traffic is in that range.
normally its led indicators are off and when I turn on light then it shows signal for 0.5 sec while eg dimmer sends on/off command to controller
in my case majority of the modules show constantly 100% signal on the indicator scale. there is something being transmitted all the time and probably over routing it gets everywhere...
how to debug this?
i started turning off fuses but did not get to the cause yet. this seems possible way to me
any experiences in such cases?
1 answer to this question
