Guest samuelboerhoop
When I plugin the plug in the power socket from my denon receiver, internally the unit is initializing different settings, like network, etc... when i plugin the unit, the receiver is set to standby, ok. I want to make a lua code whereby it makes a loop with repeat / until...until i get a code back from the unit if it's in standby mode, or on mode, from there it should continue, see below. but it's skips the repeat/until... When the unit is plugged in, no code is been returned... So i was thinking:
instead of this: "if not(trim(result) == "PWON" or "PWSTANDBY") then"
use "if (trim(result) == """) then"
Are there other ways to detect an empty string ?
With other words: When no code is been returned, stay in this loop until PWON or PWSTANDBY is been returned.
Please some help would be appreciated. Thankss a lot
13 answers to this question
