Stella Z radiator
barend121
Dear fibaro friends,
I bought a stella Z radiator to setup my home temperature. In the main screen I see three devices:
1.  reads out temperature, (current 53 celsius), can set temperature, can select between heat and energy efficient heat
2.  reads out the temperature (current 26)
3.  a possibility to: off, energy safe heat, heat
How can i manipulate these values? Do I have to do something special with parameters? Or does it work right out of the box?
Hope you guys can help me!
Greetings,
New/fresh fibaro user! Barend
Dear All,
I have bought Stella-Z heat valves.
Now it is connected to Fiabor Home Center Light.
In menu I see please where I can change teperature and in antoher please actual tempreture.
Additionally under the teperature switch - there is shown also some temperature.
Wakeup time is set 300 sec.
So when I set some value of temperature - it is changing all the time, I check fibaro menu.
Why is it changing without my ingeretion?
