HRT4 ASR-ZW scene not working after update v4
LeoHen
I had a fairly complex scene running before the update, which i stitched together from code on this forum about a year ago.
It checks all my valves set temperatures and compares them with the nearest temperature sensor.
If there are valves that need the boiler to be on, i turn it on, if not i turn it off.
This happens all day long with a lot of sleeps.
Now before the update the code worked fine and used the following boiler functionality:
  local boiler = 139
boilerStatus = tonumber(fibaro:getValue(boiler, 'state')) -- Check current state (1 = on 0 = off)
  fibaro:call(boiler, 'turnOn') -- Turn boiler on
  fibaro:call(boiler, 'turnOff') -- Turn boiler off
The state variable still seems to work.
The turnOn and turnOff actions are gone...
I can only call:
reconfigure() -- every device has this...
setmode() -- don't know how to use this => must i give an on/off parameter somehow? I have never used an action/function that requires a parameter... Any tips?
Thanks already
Florian
4 answers to this question
I have checked mine.
I have the same situation as you. I cannot turn it on or off, only reconfigure and setmode.
When I moved to a new house I did a factory reset and included everything in version 4. So It is not your update. Maybe there is already a bug opened for this. I don't know.
This being said, is the only thing I can help you with (I'm sorry I dont have a solution for you).
local boiler = 139
I can only call:
Thanks already
Florian
to turn on use
fibaro:call(boiler, "setMode", "1")
to turn off
fibaro:call(boiler, "setMode", "0")
Cheers
Mike
Just tested it. This works. Thanks Mike!
No problem, just need fibaro to fully support it now
