Aeon DSB28-ZWEU E2 on HCL (4.057)
ChrisWhite
Hi all,
I have a HCL with 4.057 Software Running.
I have an Aeon DSB28 that is giving me some real problems.
The Aeon has been added successfully to the HCL and the template loaded. However there are several slaves that are giving out data that I don't want. If I delete them, they just come back.
I only have Clamp No.1 installed (230VAC, UK Single Phase), so Clamp 2 and Clamp 3 are non-existent.
The data found on the Meter Total updates regularly and seems to keep track of usage. However, the Clamp No.1 actual reading is static, never updates and just gets added to the Meter Total meaning the power usage shown on the top of the screen is way out from what I'm actually using.
The problems started on upgrading to 4.057 so I'm guessing its probably a software bug that I'm stuck with?
Anybody else had issues?
Just hide unused slaves in advanced configuration
  • 3 weeks later...
