midi 7
I have four Danfoss thermostats connected to HC2.
I have noticed that they are marked as dead from time to time. It is probably pointless.
If they wake up every 15 minutes (wake up interval set to 900 sec.) and then communicate with HC2 to set up the temperature, report battery level etc. so is there a need of checking them by HC2 every 125 sec. (standard polling time)?
I think this could be the reason why they are marked as dead. So shouldn't I just set "Mark if dead" to 'No'?
If I will do this the HC2 will stop to polling them every 125 sec.?
What is your opinion - maybe I don't understand this in a right way?
Kind Regards
