LUA learning topic
Igy
Hi, I’m new to LUA and actually newer did the programing, except the pascal on high school J. However I like to learn the new staff, best way for me is learning by doing. I developed many block scenes and converted them into LUA to understand the way it works, but still have some questions I believe if answered, other users will find useful as well.
This topic should be for explanation how LUA works.
First question what is tempfunc() for and how to use it?
4 answers to this question
Could you share the code where tempfunc() appears?
Usually tempfunc is the name of temporary function created by user.
  • During my LUA learning evenings, I convert block scenes to LUA and I try to understand the logic. One of the simple scenes is attached. Goal is to turn on the socket at specified time during the selected days of the week. When I covert the ice to LUA, it looks like this:
    and only thing I don't know what is about is the tempFunc in it.
    Exactly as I thought, the tempFunc() is a local function and not part of  LUA language.
    Since the code is using setTimeout () (to create a loop for every minute) it is required to call a function, which is in this case tempFunc()
    Just to exercise you can change the name to any other and it will work.
  • Perfect, thanx for explanation!
