How to set a dimmer to a desired level in a scene
JohanSj
When I build a scen blockscene and use the command "Turn on" then the dimmer turn on the light to the last used level.
But if I use the command "Set value" and use the value "50" (or "100" or "255") nothing happens.
How to do if I want a scene to activate the dimmer to a certain level, e.g. 50%?
  • Thanks a lot!
    Works with Safari 9.0.2 on a MacBook/El Capitan. Not on IE11 on a Dell/Windows 8!
