AutoFrank 372
I have come across what I think is a limit to the number of words that the TTS engine can speak.
The following scene lua will work
but if I replace the message line with a longer message it doesn't work. (no error is given)
I think the limit seems to be around 46 characters (or perhaps its a time limit, ~2 seconds of speaking??)
'Guest' in the following post indicated that they had announcements that were much longer that 50 chars that were working fine with the 1.0.0 beta
Is this a known issue or is there a fix out there...
-F
5 answers to this question
