karlt 1
I have a Yale lock and a Fibaro door sensor which i need help to make a auto lock scene with.
The yale lock has a auto lock after 30 seconds which is good, but it will lock even if the door is open. So I have disabled this and made a scene on my HC2 instead.
This is what I want to achieve.
1. IF lock is open for 30 seconds or more
2. AND the door is closed for 3 minutes or more
3. THEN lock
It must also lock in the instance that the lock was opened but the door wasn't, i.e. the door has not open/closed to trigger the three minute count down.
I built a scene as below but it doesn't work, can anyone suggest where I am going wrong?
I made a simple scene as below that says if front door is safe for 0 seconds then lock after 180 seconds, this works fine however if the door doesn't open/close then it never triggers.
Any help or suggestions much appreciated.
Thanks,
Karl
8 answers to this question
