Sprinkler Panel
pt13
So at the moment in order to + or - the water % or set delays in my sprinkler panel i need to go on to my computer, login and go to the panel etc........
Firstly, does anyone have a 'scene' solution to be able to set these parameters so that i can do it from my tablet/phone?
Secondly @Fibaro, it would be nice to have these parameters in the sprinkler panel on the tablet/phone.
  • 1 year later...
Hey Sonny,
When debugging the button i get this response:
line 9: attempt to call field 'decode' (a nil value)
can someone help? i'm new to these types of things
@Sankotronic any chance you can help me out?
Hey @Jamie mccrostie
Good call :)
- Set authentication
HC2 = Net.FHttp("192.168.1.162",80)
HC2:setBasicAuthentication("admin", "admin")
fibaro:debug('Button LUA Triggered: ')
-- get data table from the Sprinklers Panel
response ,status, errorCode = HC2:GET("/api/panels/drenchers")
jsonTable = json.decode(response)
fibaro:debug('Rain Delay Value: ' ..jsonTable.rainDelay);
-- change data in LUA for 0 hours delay
jsonTable.rainDelay = 0
fibaro:debug('Rain Delay New Value: ' ..jsonTable.rainDelay);
-- send updated table to panel
json = json.encode(jsonTable);
HC2:PUT("/api/panels/drenchers", json)
fibaro:log("ready")
fibaro:debug('Button LUA Finished: ')
@amurray85 you need to put your hc ip address HC2=Net.FHttp("your HC ip address here",80) and then in the next line your username and password
if yourve upgraded since fibaro id it wont be ("admin","admin") any more thats why im asking what version software you have.
Edited by Jamie mccrostie
yeah i worked that bit out.. any chance you can attempt creating the virtual device and see if you can replicate the error i'm seeing?
If you copy and paste the code you have altered not the original
-- Set authentication
HC2 = Net.FHttp("192.168.1.13",80)
HC2:setBasicAuthentication("myusernamehere", "mypasswordhere")
response, status, errorCode = HC2:GET("/api/panels/drenchers")
fibaro:log("ready")
this is the guide i followed @Jamie mccrostie
fibaro:log("ready")
@amurray85
@Jamie mccrostie
..sorry just working from my phone so a bit limited in what I can do....
I had a quick look at the api and drencher still seems to be available so that's goes news...
If you go to http://192.168.1.13/docs
Scroll down to panels and drenchers and select option ti get all drenchers ..
That'll show you what's setup on your system
Second thing ..
you should try the Ip 127.0.0.0 port 1111 method to access the api
I can recall the syntax exactly but if you look at the code at  the start of my smart message hub scene you'll see it there  ( I use it to create variables)
Give that a whirl and I'll be at a computer later and can take a better look ..
-f
Edited by AutoFrank
so lads, it appears as if the buttons still work even with the message in the debug.
I have a sneaking suspicion that its telling you that the value is now 0 even those its written the value..
Can someone confirm? i'm a bit of a programming n00b lol
So the buttons are changing rain delay in sprinkler panel?
Im not home so cant look, I recon its trying to change a value that doesnt exsist. AutoFranks on the case he will come thru when he gets home.
7 minutes ago, amurray85 said:
thanks boys! love your work. this community is awesome.. lets hope this functionality gets built in
I take it that means its working then :mrgreen: good th hear
