Somfy wireless motor
ydabbagh
Hi
I have a few wireless Somfy motors for my roller blinds installed in my house- will the Fibaro Roller Shutter 2 work with it?  If so, how?
Yasser
I have a similar problem, i have RF controlled blinds all over my house and because they are wireless i cant connect a relay.
No your out of luck sorry, you can use the RTS transmitter or RFXTRXE plugged into a Pi running a webserver and call the remotely. I can share the python scripts for the Pi if you want but unfortunately that is your only option. It would be great if you could plug RFXTRXE into the HC
yes, this is what im looking for.. someone who has done it this way.  I use GlobalCache Itach Flex for IR  use, which works like a charm, so want to do similar for RF.
Get yourself a Raspberry Pi or other Linux machine and use Domoticz to control the RFXTRXE and then setup FibaroLink
FibaroLink works with the latest release of HomeCenter? I thought there had been an issue for almost a year now?
I've been using FibaroLink to update a label on a VD for 1-2 years, so it's working. (i'm on v4.080)
But updating a global variabel on the HC2 stopped working some time ago.
Just tried it here to update a label and its failing to send data according to the error log in domoticz v2.4088 / hc2 4.081
maybe something to do with running on my nas then? but i know it has worked before but well over a year ago! do me a favour and snapshot your fbarolink settings page to ensure i am not losing my mind
EDIT:
Just updated to the very latest Domoticz as i was well behind and no change
The ones inside the red "square" is working, updating 2 vds and running 1 scene.
Thank you... Other than IP address and credentials exactly how I use it. Can only assume my synology is blocking something! I wonder what the heck is happening?
  • 3 months later...
I have 8 somfy rts blinds, which this weekend I have finally been able to control using the following:
Fibaro Home Centre 2
Somfy RTS 485 transmitter
Global Cache iTach wifi
Global Cache rs485 cable
The process is not easy, and it is not two way communication, but it works and I have scenses in Fibaro which now control my blinds by time of day etc. If you have the RTS485 transmitter and need help geting it to work, let me know and I can help out.
My somfy motor works with the fibaro switch.
I have a wired somfy though, not a RF.
I have a Somfy 40 Nm Somfy LT 50 Mariner.
Build it in my self
i wrote about it awhile ago
