Google Now + Z-Wave integration
berserker
I'd like to share with you a little experiment I'm working on:
Taken from the video description:
By now I'm using Tasker to automate the voice recognition event (triggered by the AutoVoice plugin) and the REST API to control Z-Wave devices (exposed by my Fibaro home center).
The next step is to write an app on my own and to move the "logic" on another device (raspberry).
Hope you'll enjoy it
It looks promising.
Can you show an example of a REST API command that triggers an action in the HC2 from Tasker?
  • It looks promising.
    Thanks!
    The "trigger" in the video is invoked from a plugin called
    (please note that my device is not rooted).
    AutoVoice allows me to intercept Google Now commands and in my test I created 2 profiles for the following "recognition events":
    • Turn on the air in the bedroom
    • Turn off the air in the bedroom
    To be able to turn on/off my FIBARO Relay Switch (that is connected with the air recycler in the video) I need to create the following two actions (please note that the switch ID is 25):
    The FIBARO REST API requires (rightly) every HTTP request to be authenticated via "HTTP Basic Authorization" but I got some troubles in setting a custom HTTP header with the "standard" Tasker options (maybe it's possible) so I used another plugin called
    Actually the demo is designed to work on LAN (as you can see in the URL's host) but it could be obviously ported to work from remote too
    Thanks!
    Hello ,
    can you tell us how did you configure Restask?....I have Autovoice and Task .
    When i create the action in Task where should i put this api "
    Request Type =Get
    Host = 192.168.x.xxx
    return code =?
    response =?
  • Hello ,
    Request Type =Get
    return code =?
    response =?
    That's very easy, just follow these steps:
    • Create a new activity
    • Click on +
    • Click on plugins
    • Select RESTask
    • Click on the top/right pen for editing it
    • In the the "host" field enter the URL
    • Enter you FIBARO Home Center user and pass
    • Have fun
    Well, it does work. Thanks for that.
    I have succesfully triggered devices on and off and also started fibaro scenes, but i do not get virtual devices responding.
    The api command:
    works when sent from a browser but it does not when it is played on Tasker.
    Any clues?
  • Well, it does work. Thanks for that.
    The api command:
    Any clues?
    Hi, sorry for the delay!
    I tested a virtual device with the same api command and it does work, in my case I have something like this:
    /api/callAction?deviceID=35&name=pressButton&arg1=1
    I can suggest for debugging purpose to test the api with curl, i.e.:
    curl.exe -v "http://<user>:<pass>@192.168.1.3/api/callAction?deviceID=35&name=pressButton&arg1=1"
  • a little example about how to invoke the REST API for a Virtual Device/Plugin (in this case it's the Fibaro's Wake On LAN plugin).
    Thanks. Nevertheless, I found a different way to trigger these API actions without the need to code every single one in the tasker app.
    Have a look :
    hi
    i have used autovoice and tasker in the past with imperihome, so if you install imperihome app aswell then tasker has a plugin for that so you dont need to send any REST API commands over the internet.  The only thing is imperihome plugin in tasker can only run scenes so unfortunately you would need to create a scene for everything you want to run.
