kariem112 3
I have the following problem:
When setting parameter 5/6 and 7/8 so that a light can be dimmed slowly instead of really fast, the dimmer also turns off very slowly. Is there any solution for that? There is no physical switch connected to it, only a battery powered wall switch.
When powering the dimmer down in interface, slow. When using association,also slow. There does not seem to be any way to turn off the dimmer quickly, while maintaining the slow dimming option....
4 answers to this question
