Fibaro smoke Sensor batterylevel 0%
waltdomotica
I use a scene (luacode) to see the values of certain battery operated devices. The values are for example,: the ID, the room where it is in, the type, the wakeup time and the batterylevel.
For all the doorsensors (Fibaro) and the garagedoorsensor (Vision) this works perfect.
Only, the Fibaro smoke sensor V3/3 indicates that the batterylevel is 0%, nevertheless that the devices is new and the batterylevel-indicator in devices shows a 100% full icon.
I suppose this is a bug. Anyone with the same problem? And can it be fixed?
4 answers to this question
I have same problem with smoke and motion sensors. I use master ID and always get that battery is on 100% even they are now installed for more than 3 months. Maybe this is ok because level indicator on web interface also shows green battery on full. But I would expect that after three months this level will drop for some percentage. If I use slave ID then always get 0% for battery level. Flood and door/window sensors give actual battery level with master ID.
bug? wait .. checking my crystal ball
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Depends on firmware version one might get wrong value (nil) when checking master device, where slave sensor is showing proper value (FGSD002 v3.1), where on other versions this works (FGSD002 v3.3).
  • As well the ID 's of the  smokesensor, as the heatsensor as the temperature sensor give as result of batterylevel 0%
    The HC2 sotware version : 4.080
    Device type : FGSD002 V3.3
    Indeed, since I installed doorsensors and smokesensors 4 months ago, the batterylevel didn 't reduce. As well the icons on the device page as from the sensors that give the batterylevel result  from running the lua-code scene. Let 's hope the level keeps the same the rest of the year!!
    My HC2 is on 4.080 firmware and motion sensors are on V2.6 and V3.2 while smoke sensors are V3.3 and they are all reporting 100% battery status when used master ID and 0% battery status if used slave ID.
