Momos 101
I am struggling to understand how the heating panel works together / or not with the AC panel.
The setup is like this:
In the same room there are: 2 Danfoss radiator valves LC13, 1 Room Thermostat Danfoss RS, AC controlled by a Remotec ZXT-120.
During the winter I have "moved" the 4 Remotec icons to a dummy room as AC was starting on heating whenever the heating panel demanded to turn up the heat and I wanted to heat the room only using the radiators.
Now it is getting warm outside and I will soon need to cool down the room. So what I did is I moved back the Remotec controls to the room, set the main temperature sensor the Danfoss RS, set up the AC panel and I hoped I will start to cool down the room by turning the AC on cooling. No dice... Radiator thermostats just followed the heating schedule and AC turned on heating.
So I disabled the heating panel and left only the cooling panel. Still no dice, AC does not turn on cooling.
So I guess my question is: how are these panels supposed to be set if I got all of the above devices in the same room but during winter I want to heat only with the radiators and during summer to cool with the AC?
Thank you
PS: or is there a bug and the Remotecs are integrated in the heating panel but not in the cooling panel ?!
Would be great if someone from Fibaro could shed some light on this.
28 answers to this question
