RAM keeps filling up
Guest Dennis
Guest Dennis
i have a problem with my HC2.
Over the last 4 weeks every 2 days my system crashes. I directly installed the latest, stable, version 4.800, it didn't work.
Even now i installed the beta 4.082 but it chashed again tonight.
My RAM memory keeps filling up and when it reaches 100% the system crashes.
I dont no why my RAM keeps filling up, it has been working flawless for almost 5 years now. And out of the blue the problem is here.
What i did:
Disabled all events. ( no luck)
installed the latest version ( no luck)
Updatet the LUA scenes ( NO luck)
can someone explain why my RAM keeps filling up??
Or help me fix this??
thnx!
8 answers to this question
What i did:
thnx!
HI,
I had this issue some time ago and started a thread on it
my issue was some scenes  but you might find some ideas
regards
-Frank
Guest Dennis
  • Thanks for the info.
    I did update the scenes.
    Now i have disable ALL my scenes. But still every (1) hour my ram is filling up with 1 % ?
    Guest Dennis
  • Let me check. 5 min. thanks for the fast response
    Guest Dennis
  • Do you have any VD:s with code in the main loop?
    No. checked
    Guest Dennis
    What code do you use (or what is the best code) to autorestart every 5 min a scene ?
    See links below
    and
    Guest Dennis
  • See links below
    and
