Wiring for a Fibaro dimmer 2
remcoploeg
I have installed several (20+) Fibaro dimmers in wall outlets. But I have a question regarding the following problem. In my house one of the lights is behind a normal plug. Because I transformed it to LED lights my AEON plug doesn't work anymore. So I bought a Fibaro Dimmer 2. But I don't get how to put the Fibaro dimmer between the normaal plug and my LED light.
So there is a direct connection to the LED lights with blue and brown. So do I need to:
- From the plug the brown in L of the Dimmer
- From the Plug the blue in the n of the dimmer
- From the LED light the brown in the arrow sign of the dimmer
- From the LED light the blue in the n of the dimmer
Is this correct?
thanks in advance,
Remco
Is this correct?
thanks in advance,
Remco
 This is how it's done with 3 wire connection
