[Virtual Device] for Multi-Sound Siren Philio PSE02
i have a Philip PSE02 Multi-Sound Siren. This devices will show as a switch unter HC2 with Beta 4.082 firmware. If i switch it on, there is no sound but the optical alarm will flash. Now i have found a solution to switch to the different sounds with a SendData command. Here is a
where are documenting how the sounds can enabled.
One example is:
How can i setup the sound in a virtual Device with fibaro and lua?
Hope you can help,
Udo
9 answers to this question
I have also this Siren and I would like to see it running with the multisound option on the HC2.
I would be very happy for any update or feedback on this.
Guys I'm a newbie and I would like to learn more about LUA and the REST API function of the HC2.
Is it possible to use this kind of method that I found here in the Forum to send data to the Siren module?
Parameters set for RGBW module (
Of course this is indented to set an RGBW module but how could I change this to send the following commands:
Here an another code snippet that I found on Google:
Any help in proceeding here is very appreciated  :-D
How can it be that mainly all other brands has this fixed by now and Fibaro don't? Maybe because of different interests?
Did anyone manage to change the sounds and use the other sounds as the door chime.
I have the DLINK DCH - z510 that should be the same device (rebranded).  Cannot get the other sounds to work, only the on/on functionality of the default alarm sound..
Same challenge over here ... could really need some help :)
HELP ! :roll:
Edited by Patrick
