WUWeather scene - version = "{3.0.5}"
jompa68
Fetch data from wunderground.com, send morning and afternoon forecast to your smartphone using Fibaro app, Telegram or Pushover.
Data from wunderground.com can be from a PersonalWeatherStation(PWS) or nearest LocationID(LOCID)
Example of forecast and pushoptions to use. 1'st value is smartphoneID, 2'nd value is morning forecast, 3'rd is afternoon forecast, 4'th is pushoption
Sending as Pushover message requires an own scene that monitors Pushover variable, read about it here:
All important keys like API keys, tokens etc will be saved to variable panel.
Supports many languages (EN, FR, SW, PL, NL, DE, NO, RO, CZ, GR, PT, RU (default is en))
Complete lua code (save in a new scene)
Updated to this version and all is working, thanks for the update!!
I might have an idea that could come in handy for some people:
Set a var for days without rain, user set it to lets say 3 and a var for days temperature above 25C that will send a push like "water the lawn" and after the push the counter is reset. If you don't want to receive these pushes set it to 0.
Again, this is not a feature request just a mind-fart of me. I am no programmer else I would have tried my self
Thanks again,
Jim
It worked yesterday, now I'm getting this error:
[DEBUG] 17:36:09: Now downloading data from www.wunderground.com
[DEBUG] 17:36:09: this key does not exist
I created a new WU api key but still the same...
The variable said "NAN" when I try to put it in my self I only get numbers and not letters.
  • Remove all variable and save scene, will recreate all again
    I deleted the var's, saved scene then I get this:
    [DEBUG] 18:35:50: line 133: attempt to concatenate a nil value
    No var's where recreated. when I try to add them manually the telegram tokens are to much text
    Okay take your time
  • Code is corrected, first post updated to new version 3.0.2
    Udated and it runs now, see if I get my morning push tomorrow.
    Thanks again
    Strange, I use the WU.sendPush = true to my iPhone end get the message two times a day.
    it's not possible to remove this old message, so not in my iPhone and iPad.
    Remove App, download again, but not possible to remove post envelope in the screen.
    Can somebody explain how te remove message?
    Same problem on Android, phone and tablet app. I think we should raise this issue on the fibaro apps section of the forum.
    Jim
  • if you logon with admin in app it will work to remove post
    Didn't know that, will do so
    My ISP is doing network upgrades so the connection is lost often. Is it possible to add some sort of recovery for network time-outs? the script stops running as that happens.
    Jim
  • First post updated
    You can update from
    to
    WU.smartphoneID = .........
    wasn't there. is that ride
    and get still
    [DEBUG] 17:42:04: line 606: ')' expected near 'fcst2_mobile'
  • WU.smartphoneID = .........
    Is changed/removed and replaced with this
  • and get still
    Hmm i don't have that error and the last ")" is there
