NoDon Wall switch with Fibaro HC2
HansS1964
Hi there, I just started to explore LUA.
Last week i bought a NoDon WallSwitch (4 buttons, 4 functions per button: SinglePress, DoublePress, Hold, Release). I needed to program it to start separate scenes (this was the easy part) and also be able to use the Hold/Release option to set 2 dimmers separately to a specific level. I could not find any samples, so i decided to write my own (actually by first own LUA script).
Please have a look (reuse it for your own is much appreciated). Any comments or feedback is appreciated.
%% properties
166 sceneActivation
%% globals
-- Change the value below to match the ID of the wall switch of your choice
local WallSwitch = 166
-- NOTE : Change the value also in the header to match the ID of the wallswitch
-- LUA code for NoDON WallSwitch (4 buttons, 4 triggers each : SinlgePress, DoublePress, HoldPress, HoldRelease)
-- Hans Somers , v0.6 , 14AUG2016
--  v0.1 Button 1,2,3,4 are programmed to start a separate scene with Single or Double press
--  v0.3 Button 2 and 4 are programmed for PressHold to set a dimmer to desired level
-- Button layout (this is for NoDon Wall Switch)
-- Button       SP    DP    HP    HR
-- Button 1    10    13     12      11
-- Button 2    20    23     22      21
-- Button 3    30    33     32      31
-- Button 4    40    43     42      41
local ButtonPressed = tonumber(fibaro:getValue(WallSwitch, 'sceneActivation'))
-- Declare button values (change this for other switches)
local Button1_SP = 10
local Button1_DP = 13
local Button1_HP = 12
local Button1_HR = 11
local Button2_SP = 20
local Button2_DP = 23
local Button2_HP = 22
local Button2_HR = 21
local Button3_SP = 30
local Button3_DP = 33
local Button3_HP = 32
local Button3_HR = 31
local Button4_SP = 40
local Button4_DP = 43
local Button4_HP = 42
local Button4_HR = 41
-- Scene IDs for scenes to trigger with Single Press or Double Press
local SC_Scene01 = 9
local SC_Scene02 = 10
local SC_Scene03 = 17
local SC_Scene04 = 19
local SC_Scene05 = 12
local SC_Scene06 = 11
local SC_Scene07 = 20
local SC_Scene08 = 21
-- Dimmer  1 to be set using HoldPress, change this to your Dimmer device
local ID_Dimmer01 = 157
-- Start level for dimmer 1
local LV_Dimmer01 = 0
-- Increment value for dimmer 1
local IN_Dimmer01 = 5
-- Max value  for dimmer 1
local MX_Dimmer01 = 100
-- Dimmer  2 to be set using HoldPress, change this to your Dimmer device
local ID_Dimmer02 = 161
local LV_Dimmer02 = 0
local IN_Dimmer02 = 5
local MX_Dimmer02 = 100
if ButtonPressed == Button1_SP then
-- Start scene for Single Press Button 1
  fibaro:startScene(SC_Scene01)
elseif ButtonPressed == Button1_DP then
-- Start scene for Double Press Button 1
   fibaro:startScene(SC_Scene02)
elseif ButtonPressed == Button2_SP then
 -- Start scene for Single Press Button 2
  fibaro:startScene(SC_Scene03)
elseif ButtonPressed == Button2_HP then
-- Press and Hold Button 2 to set the Dimmer level
-- Turn Lamp on at current dimm level
fibaro:call(ID_Dimmer01,'turnOn')
while ButtonPressed == Button2_HP do
  -- if Max level reached reset to 0
  if LV_Dimmer01 >= MX_Dimmer01 then
    LV_Dimmer01 = 0
-- Set lamp to desired level
    fibaro:call(ID_Dimmer01,'setValue',LV_Dimmer01)
-- Increase LampLevel with  IN_Dimmer01 %
    LV_Dimmer01 = LV_Dimmer01 + IN_Dimmer01
-- wait 0,5 sec
   fibaro:sleep(300)
-- Check again for Button Pressed
elseif ButtonPressed == Button2_HR then
-- Do Nothing
elseif ButtonPressed == Button2_DP then
 -- Start scene for Double Press Button 2
  fibaro:startScene(SC_Scene04)
elseif ButtonPressed == Button3_SP then
-- Start scene for Single Press Button 3
  fibaro:startScene(SC_Scene05)
elseif ButtonPressed == Button3_DP then
-- Start scene for Double Press Button 3
  fibaro:startScene(SC_Scene06)
elseif ButtonPressed == Button4_SP then
-- Start scene for Single Press Button 4
  fibaro:startScene(SC_Scene07)
elseif ButtonPressed == Button4_HP then
-- Section for Press and hold Button 4 to set dimmer to specified level by holding the button
-- Turn Lamp on
fibaro:call(ID_Dimmer02,'turnOn')
while ButtonPressed == Button4_HP do
  if LV_Dimmer02 == MX_Dimmer02 then
    LV_Dimmer02 = 0
  fibaro:call(ID_Dimmer02,'setValue',LV_Dimmer02)
    LV_Dimmer02 = LV_Dimmer02 + IN_Dimmer02
-- wait 0,5 sec
   fibaro:sleep(300)
elseif ButtonPressed == Button4_HR then
-- Do Nothing
elseif ButtonPressed == Button4_DP then
-- Start scene for Double Press Button 4
  fibaro:startScene(SC_Scene08)
else
  fibaro:debug('Error, unknown button pressed:' ..  ButtonPressed)
  if ShowDebug == 1 then
    fibaro:debug(ButtonPressed)
  • 4 months later...
Hi.
Some time ago, this post, but still...
What is your experience with this switch over time? Stability? Does it really work?
I've had some issues with another similar wall switch...
OleK
Guest FredrikKarlsson
I have four of them, and they work great.
The one issue I have seen is that with sceneActivation, long press is sometimes observer by the remote when you intended a short press. Simple fix is to have scenes react both on single click and long press if you don't explicitly need long press functionality.
Otherwise, they work great!
