TW1979 6
This is an update of the first post which now contains the workaround I created (with code found all over the net). Makes it easier to find what you are looking for when you open this thread .
This is more a replacement / edit for the original plugin. I still use the original Plugin, so I have a device that is registered in the system as a Thermometer and an Humidity Sensor (devices 112 and 113, whose values are updatet by the VD). For the moment, I don’t think this can be done with a VD alone.
Worth mentioning: don’t make too many calls in a short timeframe to the Nest API, it will just slow down everything.
I did it this way, but you can change whatever you like, this makes programming fun .
Getting started: (For easy first steps to get to your access token, use something like “Postman”)
using something like Postman (I did it using Fibaro scenes, but Postman is easier).I made these Global variables:
I made a VD with some labels and buttons. I also did a VD with a slider to set the temperature, but that didn’t work the way I wanted it to. The slider is always 0 - 100. I edited it to be able to choose a temperature between 10°C and 30°C, but when you move the slider, the value isn’t visible “on the fly”. Changes to the slider are only possible with reload of page, for as far as I know. The new temperature did come in a label, but I found it to sluggish to use. Look at the attached images for more info.
The main loop for the VD (I like "," as decimal seperator, not ".", you can delete all that off course):
The code for my button Temp +
The code for button Temp -
The code for button "Instellen" (you eventually have to push that button, to set Nest to your new wanted temp, I did this to limit the API calls) Scene 66 will follow
The other buttons are readable in the images.
The Nest Refresh scene, which updates the global variables. Runs once a minute, don’t run it too fast. Just change the << >> values to your own.
The Scene to set Nest to "Home" (scene 65)
The scene to set Nest "Away" or "Eco" (scene 64)
The scene that sets the new temperature to Nest (scene 66)
Hope some more people can be helped by this
Edited by TW1979New first post
11
6
4
Oct 14
19
Sep 24
3
Oct 13
3
Nov 5
3
TW1979 18 posts
malzbier 11 posts
morpheus75 6 posts
Sardar 4 posts
Oct 14 2016
Sep 24 2016
Oct 13 2016
Nov 5 2016
TW1979
Sure, but remember, the API has you go through a few stages, so the code is kind of "incomplete" when you use it like this. First, get a developer account from NEST. Then you get a "ProductID" an
47 answers to this question
