[Feature request] - Z-Wave to DALI converter/gateway
jakub.jezek
I'm seeing increasing popularity for DALI for Lighting solution. We have some solution for DALI with
gateway called DALInet, but there are only Scenes and custom virtual device for control Groups of devices for DALI.
Fibaro team, could you please make Z-Wave to DALI converter, that can be functional with DALI Lights?
We literally tested a solution for this yesterday using the PWM outputs of the RGBW module through 2 converters (PWM to 0-10v then 0-10v to Dali) for the Floss Running magnet series of Dali lights.
It works, but we have to do some stress testing.. It will be a couple of weeks before I know how well it serves as solution.
I'll share what I can when I can... the PWM to 0-10v device was made especially for this.. not a "off the shelf product"
The 0-10V to Dali convertor is the Lunatone Art. Nr. 86468352
    Well yeah, that can do it as well, but still there is so much converters. I would like to have only one converter (Z-Wave to DALI bus).
    1 minute ago, T.Konopka said:
    We only support Z-Wave devices. There are no plans to introduce any changes in that.
    Well, DALI lights do not suffer ripple control issue like Dimmer 2. But this could be just a something to think of, when Fibaro will be thinking about what to build next. Integration with DALI ballasts would be nice.
    • 1 year later...
    He, I would like to know if you finally manage by using the Lunatone converter to use the zwave dimmer module with a dali dimmer lamp.
    Thanks in advance
