kunalsab 0
Hi!
I need to create this functionality in LUA Code on Virtual Devices:
Aim: To toggle commands each time that button is pressed.
Description: The Virtual Device button called “Cursor Left” needs to save Two Commands “Global Cache Executable : InfraRed Code 1” and “Global Cache Executable : InfraRed Code 2”.
Working: We need that each time we press the button “Cursor Left”, “IR Code 1” is sent and the second time we press the button “IR Code 2” is sent, when we press it the third time “IR Code 1” is sent and so on.
At no instance “IR Code 1” and “IR Code 2” should be sent together. It should always execute Code 1 then Code 2 then Code 1 . . . . . only when the virtual device button is pressed.
The program would be saved on each button of the virtual device, virtual device in this case would be a remote comprising of different buttons and codes.
How RC6 Codes Work : RC6 each codes is used in alternating order. After the first code gets sent, the equipment is looking for the next code.
Best Regards,
Kunal Sabharwal
5 answers to this question
