How to simplfy the following timer? :
if (Mode == 'AUTO') then
    log("Wait 120 minuter");
-- add this by 120 = 120 x  1 minute = 2 hours after one minute can check temp
for i=120,1,-1
    do
           -- 1 minute wait
          for i=60,1,-1
              do
                  fibaro:setGlobal("BathroomSetTemp", FloorBathroomTargetTemp);
                  fibaro:sleep(1000);
             log("Test Time Delay");
What logic are you trying to achieve?
How I read your current scene, it is setting the Global Var " BathroomSetTemp" every second (sleep 1000 means wait 1 second),  inside a loop of 60 (making one minute) which then outputs "Test Time Delay" at the end of each minute, which in itself loops for 120 (2 hours). The current code does not read anything to get the value of "FloorBathroomTargetTemp", so either this is being updated outside of this loop (which means this loop is doing nothing), or you need this loop to read something first before setting it.
If you are just wanting it to sleep for 2hrs then use
    Understood. But in the meantime of sleep i still would like to execute some code,  With other words, I would like to set my floorheating to manual mode and wait for two hours, but in case i change the temperature again on the thermostat that the temperature will be change again to the set temperature. But with this code I think i am not able to do so:
