unable to save block scene with scene-activation
pinou
Hi all,
I've juste updated my HCL to latest version 4.100.
Trying to create a new block scene with as trigger an octan remote device configured with scene-activation.
The scene can't be saved : I've the "rolling balls" forever... By looking deeper have seen that there are some javascripts errors :
check.js?version=1474920480617:2 Uncaught TypeError: Cannot read property 'indexOf' of undefine
The error comes from this part of the code (the red indexOf - sorry but the code is minified, so it's difficult to read or give any line number) :
blablabla ... b.isTypeOf(remoteControllerClass)&&b.isInterfaceOf(centralSceneInterface)&&a.swipe.indexOf("keyId")!==-1)return triggersArray.swipe.push(a.id+" CentralSceneEvent "+a.swipe.replace("keyId","")) ... blablabla
and the box is looping on the following URL :
http://192.168.0.100/api/scenes/50/debugMessages
Any help/workaround/fix would be really appreciated!
Thanks.
On 2.10.2016 at 2:34 PM, pinou said:
Hi all,
Thanks.
Is it related to the issue on HC2?
If yes, then be informed that the issue has been already reported to our team. I will add a note that the same happens on HCL.
  • Hi,
    Yes seems to be the same problem.
    I hope this will be fixed in next release because the workaround suggested (using Magic scene) is not working for me.
    Best regards
    According mine phone call with support, functionality was turned off on purpose, becouse of upgrade of this functionality. Upgrade for Central Scene will be in some future release. I cannot tell in which update, but they are working on it.
    I'm sorry that workarround does not work for you. For me as a technician of Fibaro distributor in CZ, it's atleast something.
    But i think they will solve it in next update, becouse this isse is also for Fibaro Button (in block scene) :D:D
