[HELP] Fibaro reports to rewire my house with 300mm2
The total power usage value reported in the top screen has always been weird. In the past it reported about 4 times my actual value, but now it reports to hook up to a 400kW power generator.
/monthly_2016_10/57f3cace296e9_20161004Powerconsumption.png.e2a04cb1b8d55e69af0e4b4281849ad1.png" style="width:435px;height:auto;" />  :shock: That's about 520 Amps! I would need 3 phase cables with about 300mm2 wires for that......:mrgreen:
Fibaro, can you please fix this in the next update and add an option to exclude a main power measuring device from adding it's value to the total value (prevent doubling)?
EDIT: I compared my actual usage with the reported one. I looks like you only have to remove the k from kW and add an option to prevent doubling.
Edited by Lambik
I'm looking my consumption and it looks ok:
Maybe there is problem with one of the devices that is giving wrong readings?
Edited by Sankotronic
Attachment quota filled up / deleting older stuff sorry :-(
Hi Lambik, I already had this issue with aeon 2 clamps where the total consumption was in the hidden devices and the setup was incorrect. Don't know if it can help, but maybe you can have a look into the hidden device if on is causing the trouble.
I still have some little discrepancies between consumption panel and the header but less then 10w and no time for the moment to investigate further.
Edited by Tony270570
