[SUGGESTION] It should be possible to draw graphs of lux values.
sirKitKat
In fact, there should be a tool (much like the consumption/temperature graph) to graph any value you want in comparison mode with every other values.
This way, the user can compare anything they want to optimize for new scenes:
  • Lux value's with dimmer values to see when the lights are being switched on
  • Motion sensors with light switches to see if people always turn on the light
  • Temperature with open/closed doors/windows to see what impact this has on the temperature in the room
  • Lux values with temperature to see how much the sun heats up the house and if you can adjust the heating to compensate ( If lux.value > 300 then turn heating off end )
Edited by sirKitKat
Quote
It should be possible to draw graphs of ALL SENSORS! Lux, humidity, wind speed.....
+1000
  • 2 years later...
On 8/27/2019 at 1:46 PM, djashjones said:
You can but not directly. look into infuxdb and grafana.
Can you give us more information?
I need export humidity log and I don't know how
Thank you very much
