Help with swipe needed
Chris
Hi Forum,
Owning a Fibaro HC2 with some dimmers, switches and door sensors for a few years, and since a few days also a Fibaro Swipe.
Can someone help me on the way how I can program (via blocks?) with 1 swipe to control 3 dimmers? Not only switching on or off, or opposite state, but also controlling the dimming level.
I guess a variable needs to be adressed first where you select 1 of the 3 dimmers (liek left is dimmer 1, up is dimmer 2 and right is dimmer 3).
But then how can I, as a next step, control the dimmer level with the circuler gesture.
(directly to 1 dimmer I can do it, but so far not for 3 dimmers).
Thanks for all your help!
Chris
Edited by Chris
