Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
andrea.zanantoni@gmail.com
Heatit thermostat, upgrade from 1.5 to 1.8
Hi have one Heatit thermostat in version 1.5 and two of them in version 1.8.
I need to update the 1.5 to 1.8 but a cable and a software is requested.
I got the software and the update procedure.
The cable is very expensive, about 70€, is there someone that know the wires schema in order to self-made the cable?
Share this post
Link to post
6 minutes ago, Ole said:
Yeah, I was told that this would be fixed in a firmware update, but the cable you need to update is so expensive that I didn't think it was worth it (about NOK 600). They still work, only it is not very useful to have the temp sensor display the set temperature. You have a different temperature displayed than your set temp though.
Thanks for your prompt answer.
I've contacted Thermofloor and are awaiting answers from them . If there is a fault in the FW they should send that cable for free...
Regarding different temperatures - No, it was just delayed, takes about 3 seconds from I change the set-temp to the sensor updates.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
