Hello
I want to use one HCL to have smock sensors and switch actuators in garage and want to add this HCL to 3 different HC2 of 3 different units.
How can it possible ?
I think If I have a static IP for HCL, then I can add this IP with a same username/password/pin code  to each of HC2 separately. IS it true ?
anyone knows anythings in this field ?
Sincerely yours
SmART
4 answers to this question
" to "
Temat został przeniesiony z "
" do "
Guest FredrikKarlsson
I'm a bit confused. Simple answer - sure, it seems likely that each unit can have one separate HC2, and then connect to the HCL operating in the garage. Seems reasonable.
I suspect however that you need to connect them all to the same Fibaro remote access account then if you need remote access, as I know that one HC may not belong to  more than one external access account.
I recently bought a pre-owned HCL, so I know that you first then need to de-associate it from the old account before I could add it to my account.
I guess the units are too large for you to have just one HC2 or something like that, and work with hotel mode?
    Actually hotel mode need wiring.
    I am searching for wireless way.
    Dnia 31.10.2016 o 17:09, [email protected] napisał:
    Hello
    It is possible. There are no limits concerning the number of master gateway to which you can link a slave gateway. But, I believe that it may be a very complicated to keep it clean. You may have problems in associations and scenes as there may be conflicts among master gateways.
