FGK101 Door/Window Sensor EU
scorpuk
I have changed the batteries in my door / window sensors and think they are reset.
However, no matter what I do when I try to include / exclude the sensor blinks rapidly for around 7 seconds; 1 long and then 20-30 short blinks, I think, and I cannot include it.
Any help appreciated.
Ta
John
Did you keep the both parts of sensor close?
If the LED is blinking rapidly then there is an error or it is resetting itself.
Please, check
  • Hi T.Konopka,
    I kept the two parts of the sensor close when I pressed the TMP button to include.
    I have done another reset with confirmed 2 flashes that it has reset and tried to remove / add to controller and its still blinking as above.
    You pressed the tamper button? How many times?
    Please, check if you followed the procedure properly, you can find it in "Inclusion" part.
    If you have been doing everything accordingly to the instructions then I advise you to contact our Support at [email protected].
  • I pressed the bottom tamper button three times with the lid closed and the magnet touching the main body.
