nickboy 0
I am trying to create an ASSOCIATION between Fibaro Motion Sensor and Fibaro Wall Plug.
Motion Sensor sees motion -> Wall plug switches on. Both sensors work fine on their own.
I’ve read the PDF manual from Fibaro web (http://materialy.fibaro.com/technical%20presentations/HC2_A4_MotionSens_RelaySwitch_Association.pdf) but this does not help. The latest UI works a bit differently.
I have been able to get this to work using SCENES but it was way too slow. It took around 8 seconds from motion to turn on the lights. Instead, pressing light -button from Fibaro UI works instantly. No idea why there is such a massive processing delay??
Any and all help will be appreciated. I am a total newbie and need some assistance to get everything working.
I am selecting Motion Sensor -> Advanced -> Associations
GROUP 1
Single channel associations
To be set: 20
Current (on device): 20
Multi channel associations
To be set:
I have Fibaro Wall Plug selected.
Save -> Nothing happens. Notification screen remains empty. Light switch does not work.
Are there some additional settings that need to be adjusted in Motion Sensor Advance mode??
3 answers to this question
