Aeon Labs Energy Meter G2 HEM3-200A
peter_CH
Hi All,
I've installed today the AEON Energy Meter G2 (3 phases version).
Everything working fine so far, except that the total showed value is doubled...
I assume 56.0 is already the total sum of all phases, while 56.1,56.2 and 56.3 are showing the separate phases.
Anyone a hint if that's fixable, or I need to wait until Fibaro updates it's firmware?
Thanks,
Peter
14 answers to this question
What software version of our system do you use?
What firmware version of Aeon do you have?
  • I'm using 4.102 Beta. The Firmware version of the Aeon is 1.8.
    Please find the Device Template attached.
    Dnia 7.12.2016 o 13:43, peter_CH napisał:
    I did this already, but in the top left, the values are still added up :-(
    Thanks for the update. The issue has been reported.
    On 2. 12. 2016 at 6:35 PM, peter_CH said:
    Hi All,
    Thanks,
    Peter
    But it is working quite well.
    It is doubled, because energy in Fibaro is sum of all devices reporting power. So in case of HEM3 it sums total power + phase 1 power + phase 2 power + phase 3 power.
    In that what you have posted as screen it is: 14,03 kW = 7,01 kW + 3,02 kW + 3,17 kW + 824,96 W
  • understood....
    The issue is, if I disable the 56.0 device to measure only phase1,2 and 3 it still sums it up...
    So the actual issue/bug is: Even if an energy metering device is DISABLED it still being used as part of building the sum.
    --Peter
    Well, sw developer could develop checkbox in every device configuration, that reports power to energy panel. And if somebody uncheck it in device configuration, it will not be sending power reports to energy panel any longer.
  • that's surely one way of doing it ;-)
    ...the other way would be to exclude disabled devices from the sum, because they might be disabled for a reason... ;-)
    Long term, it would be nice to be able to differentiate between total power feed in (measured by the energy meter) from the grid and it's distribution across the house (measured across the actors)...
    Got the same issue in HC2 4.110. The way it displays all phases is great, but on dashboard bar it should show only total consumption.
    BTW. in mobile app for Android phone v1.11.0.1 on home screen it displays 0W all the time.
    com.fibaro.energyMeter | AEON Labs | version 1.7
    On 4.112 Beta still problem.Disabling Summary phase device is not solving power metering values.(BTW i cannot delete also the summary device).
    I have pretty similar issues. I will always get consumpiton figures (last known value, like 500W) EVEN there are no any consuption. Total consumption figures are odd. Are there any setup what could fix this?
    T
    Any update on this issue ? I have same problem with fibaro 4.140 and Aeon Labs energy meter 3 Phase version.
    Thanks!
    Edited by Anonimo
