Double Switch FGS-223 gives 3 units in HC Lite
johnologi
When I try to add my double switch (controlling two light) to the Home Center Lite i get 3 units in HC?
-1 Master and 3 Slaves
Shouldn't it only be 2 units since its a double switch connected to 2 lamps?
/John
Master must be there always, one slave is for one switch, other for other and third one for other control for scenes or association or something like that. Usually master and other slaves are hidden in the system and you don't need to worry about them. You should see only two slaves that are controlling two switches (relays).
On 12/5/2016 at 3:20 PM, johnologi said:
Thanks for the answer. So I just hide one of the slaves..
Usually after inclusion it is hidden by default. Yes, you can hide it. Here is example of my double switch:
Edited by Sankotronic
Attachment quota filled up / deleting older stuff sorry :-(
