Sending an image from IP cam to Email or Push
geeklabs
Has anyone been able to send a sanpshot from the IP camera when a sensor is breached?
I tried using sendPhotoToEmail and sendPhotoToUser both are not working for me.
I am using Axis IP M3044 with HC2 on v4.100
Any help will be appreciated.
Go to alarm panel and find SEND SCREENS option. Click on Activate button and then Edit button to select from which cameras you want picture to be sent to your e-mail when alarm is breached. I suppose that this is what you meant.
If you want to send picture if some sensor is breached (but not ARMED? ) then you need a piece of LUA code that will be triggered by sensor, scene is ok and this code:
Where 386 is your camera device ID and "55" is your user ID. It works for my Foscam cameras on 4.100.
