Day/Night variable check
amatt
I am trying to create a day/night setup via lua. Where at 8 am-10pm the variable is set to day and at 10pm-8am the variable is set to night. I cannot successfully do this via a block scene so i have used LUA to do this. Could someone help me look over my code to see if this is correct as i am fairly new in LUA. Thanks!
%% autostart
%% properties
%% globals
-- Only need to call getSourceTrigger once
-- For better debugging, I moved it to the top,
-- before countScenes
local sourceTrigger = fibaro:getSourceTrigger()
fibaro:debug("Script started because of: " .. sourceTrigger["type"])
if fibaro:countScenes()>1 then
 fibaro:debug("Scene already running, aborting this one")
 fibaro:abort()
if (sourceTrigger["type"] == "autostart") then
 while true do
   local currentDate = os.date("*t")
   -- Do the time-string manipulation thingy here, instead of in
   -- each and every if-then statement
   -- %02u means unsigned int, 2 wide, leading zero
   TimeAsString =  string.format("%02u",currentDate.hour).. ":" ..
   string.format("%02u", currentDate.min)
   fibaro:debug("TimeAsString: ".. TimeAsString)
   Day_night = fibaro:getGlobalValue("Day_night")
   fibaro:debug("Day_night: " .. Day_night)
     if
       currentDate.wday == 1
       or currentDate.wday == 2
       or currentDate.wday == 3
       or currentDate.wday == 4
       or currentDate.wday == 5
       or currentDate.wday == 6
       or currentDate.wday == 7
     and
     TimeAsString == "8:00"
     then
     fibaro:debug("Setting scenario number 1")
     fibaro:setGlobal("Day_night", "Day")
       elseif
     and TimeAsString == "22:00"
     then
     fibaro:debug("Setting scenario number 2")
     fibaro:setGlobal("Day_night", "Night")
        else
     fibaro:debug("Current time doesn't match any scenario")
    fibaro:debug("Scene not started, this is autostart-only!")
end -- end of sourceTrigger["type"] == "autostart"
It is pretty simple to do via Block scenes, it would look like (attached)
The same in LUA would look like:
%% autostart
%% properties
%% events
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "05:00") )
then
    fibaro:setGlobal("TimeOfDay", "Morning");
setTimeout(tempFunc, 60*1000)
tempFunc()
else
if (
then
