Scene Activation Double Switch 2
Landshark
Hi All,
Question is it possible to activate a scene with the Double Switch 2 (FIB_FGS-223) . If I go through the advanced parameters then parameter 28 says: Parameter 28 S1 switch - scenes sent
This parameter determines which actions result in sending scene IDs assigned to them. But if I try to create a new scene I don't see the option "sceneactivation"  Is this a bug or am I doing something wrong?
Thanks!
It would seem no but
Maybe associate switch 2 to dimmer which has scene activation, then read fibaro scene activation info in e learning re setting up scene ids to switch function
confusing when double switch 2 has  those peramaters refering to scene activation
" to "
Temat został przeniesiony z "
" do "
  • 5 years later...
Has this ever been fixed with an update or has anyone been able to get it working. I would love to be able to triger a scene with a hold of the switch.
