Multiroom Heating Controller
BusterB1959
My project was to write a multiroom heating controller to give indipendant control over each room using as much as the built in functionality of Home Center 2 as possible.
Starting point: Create multiple rooms in the heating panel in accordance with the
I did have some code to enumerate from these panels and get the following from the JSON files http://yourHC2IPAddress/api/panels/heating &  http://yourHC2IPAddress/api/rooms
Room Name, Room "Default Thermostat" & Default Temperature Sensor As I failed to add them to my array roomsArray I abandoned this for the time being. (Any developers want to help here???
You add your rooms to the roomsArray, set the HeatON and HeatOff as you need them these will stop overshoot of Temperature. - Any developers want to turn this in to a heating PID?
I have been running this now for a couple of months without problem, and even moved it to other HC2 controllers.
Make a LUA Scene, drope the code in, change the Variables and away you go.
My setup and all I have tested with:
HC2 v 4.1x
Danfoss LC-13 TRVs these control the radiators and also act as a Thermostat for any room that does not have a external Thermostat
Fibaro or AEON Multisensor for Temperature Sensor
Secure SRT321 Wall thermostat & Secure HRT boiler Receiver - This was so i could put in manual mode if anything went wrong
Happy to have suggeestions and additions! Enjoy!
Brent
Brent
