I have recently purchased some Fibaro modules and the HC2. I have been successful in adding Dimmer 2 modules but no luck with both single and double relay switches.
Along with my Electrician we have tried everything to add the switches via both the switch and the B button but to no avail.
Does anyone have any suggestions as to what we might be doing wrong? Does the HC2 need to be in line of sight for these to be added successfully? We are adding these to a two level house both indoors and out.
Cheers
I know that this is pain in the a... but if they are far away from HC2 or there is some obstacle between relay modules and HC2 you will never manage to include them. You just have to find a way to add them near HC2 maybe bring HC2 to their vicinity and then add then it should be quite easy.
