Zipato Zipabox Indoor Siren
dannyrowe
Dear Forum,
First post from me, new to the Home Automation arena :)
With the Vera controller you can use the following codes to interact with the Zipabox Siren:
Emergency - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x71 0x5 0x0 0x0 0x0 0x0 0x7 0x1 0x0 0x0'},1)
Fire - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x71 0x5 0x0 0x0 0x0 0x0 0xA 0x2 0x0 0x0'},1)
Ambulance - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x71 0x5 0x0 0x0 0x0 0x0 0xA 0x3 0x0 0x0'},1)
Police - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x71 0x5 0x0 0x0 0x0 0x0 0xA 0x1 0x0 0x0'},1)
Door Chime - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x71 0x5 0x0 0x0 0x0 0x0 0x6 0x16 0x0 0x0'},1)
Beep Beep - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x71 0x5 0x0 0x0 0x0 0x0 0xA 0x5 0x0 0x0'},1)
Stop - luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='0x25 0x1 0x0'},1)
And the following code for a series of beeps for door entry etc.:
luup.call_delay('beep_siren’, 5)
luup.call_delay('beep_siren’, 10)
luup.call_delay('beep_siren’, 15)
luup.call_delay('beep_siren’, 20)
luup.call_delay('beep_siren’, 25)
function beep_siren ()
Would any of you super people know how to make this work for the HC2 please?
Or, perhaps I am not installing correctly and there is a more simpler/intelligent way that I should be do it??
Thanks in advance,
Daniel
4 answers to this question
Shame nobody seems to know. A multi souls siren compatible with HC2 would be good. Not sure it is possible as other multi sound sirens seem not compatible with fibaro...
  • It is a real shame!
    I have moved from the Vera Edge controller to the HC2 because I had problems, such as a simple motion detect -> light on scene taking 10 seconds to complete and false readings from door contacts and motion sensors etc.. Tried to get sorted with support but nothing more than 'wait for the next firmware to be released'.  So decided to try the HC2.
    The HC2 has solved all my issues and more with the exception of the siren multi-sounds which Vera handle quite well.
    I have that siren as well but Fibaro is not interested to have this device integrated as template including the multi-sound feature.
    it's a shame...
