Bezan 2
Because of my existing wiring and no option to change I have below situation:
Momentary double switch -> Fibaro Double Switch 2 ->
a) 1st DC 12V -> 1st Fibaro RGBW -> 1st long LED strip
b) 2nd DC 12V -> 2nd Fibaro RGBW -> 2nd long LED strip
Switch is attached to Fibaro Double Switch 2 and I would like to turn off LED strips attached to Fibaro RGBW modules.
Is it possible that Fibaro Double Switch 2 after click on momentary switch is not changing it state and only starting scene? So module will be always ON (I can turn it off via APP) and executed scene will manage Fibaro RGBW attached next.
Does any parameters combination help in achieving this?
First opion what I`m thinking about is setting parameter in Double Switch 2 as: delay OFF and put maximum possible time. Next set switch click as only counter reset. By this one turned off light should be always on, even if in Fibaro it will be OFF ( waiting to be turned off). To be sure it will never turn OFF I can add simple scene that will be triggered every 30min and forcing to click ON (reset counter).
Is there any other, better way to to this?
1 answer to this question
