VDor scene as a trigger or does it matter
Hi HC2 guru's
Would a scene with a xxx value in the header/properties or a VD main loop be more efficient (ie use less resources) if I wanted to use a sensor (motion, light, humidity) to trigger an action.
I find some of my sensors don't always react to a scene header trigger and in a vd.
I think I could also exert a better level of control with repeat triggers with a vd but I wanted to make sure that this approach wouldn't impact the HC2 excessively
-f
Edited by AutoFrank
0 answers to this question
