start Scene from lua
I really have a feeling someone will reply and i feel stupid... but..
How do you call a scene so it will start from a VD? fibaro:call(id,'start') doesn't work, and i can't really see examples for it.
7 answers to this question
GET /api/sceneControl?id=111&action=start HTTP/1.10x0D0x0AHost: 127.0.0.10x0D0x0AAuthorization: Basic <username:password>=0x0D0x0A0x0D0x0A
where id = the id of your scene
where <username:password> is your username + : + password which you need to encode (see below url).
BTW : be carefull with spaces in a vd if you copy past above string. Remove any space manually and add it again.
Doesn't fibaro:startScene(sceneID) work from VD's?
    @Tor Magnus Thanks, i knew it was something silly, i was looking at fibaro:call all the time, but sometimes searching on the internet doesn't find a lot, just random pieces.
    This is helpful:
    That helps too, but it lacks more user examples and more options. If i look at that page it says json.encode/decode is only in VD, while i have it working just fine in a Scene. So it needs a update too. I think push notifications direct where introduced too, which isn't added either.
    It's also missing the "events" trigger. Unfortunately there is the same problem on
     but that user interface is worse, but on the plus side there are more examples there.
    I don't think anyone could argue that the official fibaro documentation doesn't  leave somewhat to be desired.
    Didn't check the developer.fibaro.com for a while, but going through the documentation and having to scroll up and down while .. well you know what i mean, its horrible. Also a bit weird that there are examples of how to make a plugin while you cannot use them yet. Its like giving you a Ferrari and parking it at your front door, but you never get the keys.
