[SCENE] Simple Scheduler for running scenes
AutoFrank
I had the requirement for a very simple scheduler. The code below is a stripped down version of  @Sankotronic Main Scene code and just contains the Scene Scheduler. Thanks to @Sankotronic for his permission to post this.
The full Main Scene code can be found at
I thought this many be useful for some new users starting out or those like me that need a simple yet well written scheduler and may even be a stepping stone for some to the full Main Scene.
-f
Edited by AutoFrank
  • 5 months later...
I got this error!. why? what wrong
[DEBUG] 17:11:16: line 35: unexpected character @ character: 1 0:1 [T] line:
[DEBUG] 17:11:16: T
-- SIMPLE SCHEDULER.
-- STRIPPED DOWN VERSION OF 'MAIN SCENE' CODE BY SANKOTRONIC
%% autostart
%% properties
%% globals
if (fibaro:countScenes() > 1) then fibaro:abort(); end
local jT           = json.decode(fibaro:getGlobalValue("HomeTable"));       -- comment out if you don't use a hometable
local currenttime   = os.date('*t');
local currentwday   = currenttime['wday'];
local TimeCurrent   = os.date("%H:%M", os.time());
-- SCHEDULED SCENES SETUP -- (seperate multiple entries by comma)
local runSceneSchedName   = {"Turn On", "Turn Off"};               -- Add scene names
local runSceneSchedID     = {50, 51, jT.scene.Wakeup};                         -- add scene ID's or references
local runSceneSchedHour   = {{"18:00"}, {"6:00"}};                            -- Add times to run the scenes
local runSceneSchedWeek   = {{1, 1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1, 1}}; -- specify what day to run the scenes, Sunday is first day in array
function doSceneSched()
  if #runSceneSchedID > 0 then
    for i = 1, #runSceneSchedID do
      if runSceneSchedWeek[currentwday] == 1 then
        for t = 1, #runSceneSchedHour do
          if runSceneSchedHour[t] == TimeCurrent then
            fibaro:startScene(runSceneSchedID); end
-- MAIN LOOP
while true do
  doSceneSched();
  fibaro:sleep(59700);
    [DEBUG] 17:11:16: T
    %% autostart
    %% properties
    %% globals
    -- MAIN LOOP
    while true do
      doSceneSched();
    @Infinity
    The error is a global / reference that doesn't exist which in this case is probably jT.scene.wakeup
    it's left over from my example
    Change this
    ... to include just the two you need which is probably this,...
  • @Infinity
    Please post the full code and what error you are getting
    I can try and take a look later of somebody doesn't jump in sooner
    %% autostart
    %% properties
    %% globals
    local runSceneSchedID     = {50, 51};                         -- add scene ID's or references
    -- MAIN LOOP
    while true do
      doSceneSched();
    %% autostart
    %% properties
    %% globals
    -- MAIN LOOP
    while true do
      doSceneSched();
    @Infinity
    Comment out this line as you are not using hometable references
  • 3 minutes ago, Infinity said:
    yah its working now. thanks a lot Autofrank. and to Sankatronics the main source of this scene..
    @Infinity
    glad you got it working... :-)
  • Just now, Infinity said:
    i have question. what about pop up notification. is it working on 4.054 version.
    you will have to me more specif with your question ...
    like for ex. when the motion is breach then u will receieve  a pop up notification with button run/cancel.
    it seems like this. can I get your code for this scene
  • Sorry, that's a very different question
    I'd suggest open a new topic
    I don't have code for this specific action
    ok thanks again. see you there in next problem/error.
    is it posible if I include the lux in this scene to turn On the Lights  and when someone  turn Off the one switch lights or in application in 7:00 Pm then these lights will not turn On.
