Dimmer 2 Switch 2
qedes
Hi all
I have just installed my first dimmer2 module. How do I configure the devices associated with switch 2?
When I configured my dimmer1 modules (a long time ago) it was just a case of assigning devices to association group 2. For the dimmer2, there is Endpoint 1 and Endpoint 2, with up to 5 association groups. The online manual does not mention what Endpoint means, and suggests that I should use group 4 or 5 for switch 2, but this does not work. What am I doing wrong? What does Endpoint 1 and 2 mean?
6 answers to this question
46 minutes ago, qedes said:
Hi all
each endpoint is the switched load (There are 2), and association groups 2-3 are for S1 and 4-5 are S2
    Thanks, but what does this mean exactly? There are two switched loads?!
    If I want the dimmer2 module to control a different device that is physically separate, where do I associate it?
  • Thanks guys.
    But what does Endpoint 0 and Endpoint 1 mean? I can't find reference to these anywhere.
