AndyAA 0
Hi all,
I want to set up Notifications (Push/E-Mail) for many sensors (door/window, flood, ...). If I use the notification feature of the sensor, I can only select predefined notifications from the notification panel.
But if I write static text there (like "window open), I don't know which window it is.
Is there a possibility to include a variable in the notification panel text which uses the device name, device room or similar? Use the notification panel like a very basic template?
Otherwise I would always have to create a single magic scene for each sensor, and if I want to change text, I have to change all manually...
Andy
Edited by AndyAALink to comment
6 answers to this question
